#11 |
This combo uses probably the best automatic transmission ever used in a stocker, take advantage of it.
GEORGE MIRZA STK 1236 |
#12 |
Put in a decent 904 and B body 8 3/4 (5:13) and you will seldom have a problem.
A good second under combo without anything exotic ( check out Pomona Qual. sheet).
#13 |
Liked 10,791 Times in 2,243 Posts
stick=dana
#14 |
Liked 22 Times in 14 Posts
What about a 3rd or 4th Gen F body with an Iron Duke or a V-6? Would you have the same issues with a stick?
Rick Thomason GTOMayhem |
#15 | |
Most of my old cars may have looked like POS but I tried to get the best parts I could find. My Mustang II will follow the same pattern.
Robert Swartz - Swartz & Lane 66 Chevy II Pro 95 Achieva EF/SA, 78 Mustang II U/SA (work in progress) #354 stock |
#16 |
Liked 227 Times in 74 Posts
Im looking at building a U/S 302 2V combination but instead of going dime rocket I am going fairly cheap engine along with a very good Strange rear end with Jerico or G-Force Tranny with a Mcleod Soft Loc. It will not be a dime rocket or cheap but instead maybe a 50 cent rocket that will live and I am figuring it should cost around 20 grand or so for the complete build.
#17 |
Liked 53 Times in 16 Posts
I agree with the comments about no matter what HP a Jerico tranny with the right clutch is the only way to go. My experience withy my 68 Impala i ran with BBC (396/325) I had 100 passes on that Jerico and in my buddies SBC 68 Camaro 11.30 car has another 250-300 , tranny still good, never a problem. Also the rear needs not only Spool but Pro-Gears, my only breakage was from using "Street" (cheap) gear set.
I think the Jerico is one of the best aftermarket part made.Just my opinion. Will Lamprecht I/SA 65 Impala in progress. |
#18 |
Liked 275 Times in 76 Posts
A good trans and clutch, is a wise investment. Used Jerico's and occasionally a G-Force come up for sale and that will get you in the game. A clutch is very versatile from a tuning standpoint. If the clutch is built with low base to begin with, it allows for a wider HP tuning range. A low HP engine will not be happy if the clutch is tugging the engine down too low because of too much base. Keep that in mind when looking at clutches, and a stick car can be very consistent as well.
