09-24-2015, 09:16 PM | #11 |
Liked 116 Times in 40 Posts
Re: 79 Mustang project U/SA
Busy day today. Pulled the motor, trans, exhaust, and fuel tank. The junk pile is growing!
09-24-2015, 11:00 PM | #12 |
Liked 19 Times in 12 Posts
Cool!
Mitch Beri- The Motor City 1985 GT- “Stock-ish” 5.0 motor, AOD/ trans brake. 12.68 @ 101.31mph. https://www.facebook.com/groups/FOXBODYFLEAMARKET/ |
09-25-2015, 08:02 AM | #13 |
10-16-2015, 10:37 AM | #14 |
Liked 187 Times in 68 Posts
Update, pictures, anything....please!
Love this build, was supposed to start the same build a year ago and...it's still sitting... Living vicariously through others so give an update please |
10-16-2015, 07:36 PM | #15 |
Amen. Give us something!
10-18-2015, 12:14 PM | #16 |
Just cleaning up a few things and made a dump run to get rid of junk parts. I may have a buyer for my bracket car! If it sells it will be full speed ahead.
10-26-2015, 09:20 AM | #17 |
Well got some bad news this weekend. The buyer for my 67 backed out. So this will be a slow build but I will get it done. I'll post as I get things done.
11-27-2015, 11:22 AM | #18 |
Ok guys, i need some help. What is the best way to remove the door bars? I got no clue.
11-27-2015, 12:35 PM | #19 | |
Liked 4,578 Times in 1,733 Posts
Best way I've found is to take the door off and lay it on saw horses. You cut the out the section of the jamb where the bar is spot welded with a thin cut off wheel , front and back. Then you slide the bar out ,with the jamb pieces attached. Separate the bar from the sheet metal pieces and then tack weld the pieces back in where they were. Continue tacking until almost a solid weld, then grind and spot putty the jambs.. On some cars, you can drill the spot welds out on one end and not have to cut a window on both ends. Once the bars are out, make sure the door shell is not able to be twisted. In that case , weld the corners of the skin to the frame or brace accordingly. Those door beams add quite a bit of structure to some models. Call me if you need to.. MY
We are lucky we don't get as much Government as we pay for..... Will Rogers |
11-27-2015, 02:44 PM | #20 |
Liked 144 Times in 30 Posts
I would suggest removing all of the easy stuff first because it will be light for U/SA 3030 lbs. I have a 79 U/SA mustang Ghia with the standard easy stuff removed-heater box-wiper stuff and with a 200 lb. driver, I have to add 50-75 lbs. Brian
