Old 10-07-2015, 11:13 AM   #1
my69396
Liked 46 Times in 20 Posts
Default Head gasket bore vs compression
How important is the bore size of the cylinder vs the bore size of the gasket? Say you have a 4.200 bore and a 4.400 gasket what would be the difference in compression if I went to a 4.250 gasket?
my69396 is online now   Reply With Quote
Old 10-07-2015, 11:19 AM   #2
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: Head gasket bore vs compression
There are a lot of variables in CR. Try putting the info you are playing with into a calculator like the one in the link below to see the differences.
http://www.csgnetwork.com/compcalc.html
Dale
Dale Shearon
68 Mustang 6394
Old 10-07-2015, 12:48 PM   #3
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
Gasket bore size doesn't change compression as much as you think, thickness does.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 10-07-2015, 09:49 PM   #4
FireSale
FireSale's Avatar
Considering an 0.040 gasket, the 4.4 would create a cylinder with a volume of 9.963cc while the 4.250 bore would give a cylinder of 9.291cc.
That's a 0.672cc difference. I don't think it matters a gnats eyelash.
Dale
Dale Shearon
68 Mustang 6394
Old 10-07-2015, 11:15 PM   #5
camaroagogo
Would a 3.5cc decrease by using a thinner/smaller bore gasket make much difference? .012" thinner, about .030 smaller bore if i remember correctly. Worth changing?
camaroagogo is offline   Reply With Quote
Old 10-07-2015, 11:42 PM   #6
Very generally speaking..Yes , you should see a difference.
Worth changing?
That depends on whether you consider this work...or fun.
Old 10-08-2015, 12:14 AM   #7
camaroagogo
It's certainly a lot of both....but sometimes i wonder . Thanks
Old 10-08-2015, 08:06 PM   #8
BillK
Liked 30 Times in 17 Posts
Originally Posted by my69396 View Post
Say you have a 4.200 bore and............. if I went to a 4.250 gasket?
Chris,
You have to be careful with this. Depending on how much chamfer your machinist put on the tops of the bores you could start hanging the gasket into the chamfer area. I put very little chamfer on performance builds but some guys might put more. All it takes is 030" all the way around and you will be into the fire ring on a 4.250 gasket and that's assuming that all of the bore centers, dowel pin holes etc. are perfectly aligned with the gasket.
4.250 should be safe but its just something else you need to look at.
Bill Koustenis
BillK is offline   Reply With Quote
Old 10-09-2015, 03:30 AM   #9
GTX JOHN
I agree with Dale........Tiny change in compression for bore size variation.
John Irving
741 Stock
741 Super Stock
