Old 10-06-2015, 09:05 PM   #1
J. Kuchel
Question Low Comp. BB Chevy
I know this is the Stock and Super Stock Tech forum but I thought you guys would have the most experience running low comp. engines and having good luck with them. I have a 522 ci. BB Chevy that is a 9.6 to 1 comp. engine that I want to be a really competitive bracket engine. I was told that it won't be that competitive because it doesn't have a compression. It's going into a all round tube very light weight Camaro with a glide and 4 link rear end. I watch some of these stockers run dead on a lot. I hope you all can guide me on the right path. I don't want to rebuild it because its fresh.
J. Kuchel is offline   Reply With Quote
Old 10-06-2015, 10:21 PM   #2
Kevin Panzino
Kevin Panzino's Avatar
Liked 747 Times in 136 Posts
Default Re: Low Comp. BB Chevy
Not a problem in the least.
By the way, the winningest (is that a word?) car in the history of NHRA runs a low compression combo.
Kevin Panzino is online now   Reply With Quote
Old 10-07-2015, 07:33 AM   #3
Billy Nees
Liked 7,663 Times in 1,727 Posts
You can build "compression" (cylinder pressure) with careful camshaft selection.
For what it's worth, back in the old days when I was Bracket Racing my Camaros (smallblocks) I tried to build as much mechanical compression as I could. The higher the compression, the less a combo seems to be affected by the weather.
Billy Nees 1188 STK, SS
Old 10-07-2015, 01:48 PM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 282 Times in 98 Posts
low compression will be fine bracket racing, the main thing for consistency, isn't how much compression you have,but how well it is sealed up, a good sealing engine, valves,rings etc. will be more consistent than one not sealed up well.
Like Billy said cam is different in low compression engine.
Mike Taylor 3601
Old 10-10-2015, 11:02 PM   #5
J. Kuchel
The engine is a 522 ci. BB Chevy that is 9.6 - 1, camshaft is intake .550 exaust is .549, 260 intake 270 exhaust @ .050, Dean Oliver Q- jet, dualplane GM intake.
