Old 09-20-2015, 08:35 PM   #1
HP HUNTER
Liked 373 Times in 129 Posts
Default Peanut Port Drag Test
For several years I've been building 9.2 compression 467s with 236 peanut port heads, these engines use a 228/238/114 hyd flat tappet cam with a performer RPM intake typical HP was about 517-518 corrected HP, with about 560 TQ. Finally it looks like I will get to test one in my 68 Chevelle, 3720 pounds at a 2130 foot track. My goal is a high 6 sec pass in the 1/8 mile. Some pictures of the build.
ID:	30859   Click image for larger version
ID:	30860   Click image for larger version
ID:	30862   Click image for larger version
ID:	30863   Click image for larger version
ID:	30865   Click image for larger version
ID:	30866   Click image for larger version
Old 09-23-2015, 06:01 PM   #2
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default Re: Peanut Port Drag Test
That's cool. I always considered "Peanut Port" heads as No Good. How much RPM were obtained with those figures.
Those heads only came on "truck" motors, right? Could not build a traditional stocker motor because they never came in a passenger car, correct?
Will Lamprect
i/SA 65 Impala in progress. 396/935 "Oval Port"
Old 09-23-2015, 06:18 PM   #3
90-92 SS Chevy pickup.
I don't know what the heads look like.
Old 09-23-2015, 08:40 PM   #4
HP HUNTER
Will Lamprect
There is some passenger car combinations legal with these heads. The cam is 228/238 @ .050, very mild, I did run it to 6400 RPM on the dyno, my peak power was around 6100 RPM.
Old 09-24-2015, 08:59 AM   #5
impstocker
impstocker's Avatar
HP, Do you know year and model Chevrolet came with these 454 "peanut Ports"
Right know i am checking Class Racer Info Guide.
Will Lamprecht
Old 09-24-2015, 09:36 AM   #6
HP HUNTER
Will Lamprecht
I've been told a 1975 Chevelle is legal, not sure it came that way though.
Old 09-24-2015, 09:58 AM   #7
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
73-75 are allowed the 236 peanut, 90 454ss truck uses the 360 peanut, 91-92 uses the 148, even smaller peanut port. Seems to be plenty of SS/GT 454's using the 236.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 09-27-2015, 10:39 AM   #8
Bench Racer
Liked 99 Times in 21 Posts
I remember hearing that Lingenfelter ran a killer peanut port combination in SS back in the day.
Bench Racer is offline   Reply With Quote
Old 09-27-2015, 06:25 PM   #9
Rick Leininger Jr.
Will Lamprecht
1975 Chevy Bel Air, Impala, Caprice, Station Wagon, Monte Carlo, Malibu, El Camino.
1976 Chevy Impala, Caprice, Station Wagon.
Rick Leininger Jr. is offline   Reply With Quote
Old 09-27-2015, 09:36 PM   #10
HP HUNTER
Ready to race.
ID:	30914   Click image for larger version
ID:	30915   Click image for larger version
