Liked 524 Times in 84 Posts
If you were building a 1990-1992 Chevy 350 (245/275) for Stock or Super Stock, utilizing the NHRA Engine Blueprint Specification Guideline and Stock Car Classification guidelines, what throttle body would you "legally" use?
In the blueprint specs all the way to the right of the engine choice depending on year you will see either a number 1 or 2....go to the bottom and it says that the 2 x 1.889" (48 mm ) throttle body is the legal one..........D L Rambo...STK 1300
Liked 325 Times in 50 Posts
I was told quite recently that OEM throttle bodies only in stock and super stock. I was asking if specs say 80 mm, can I use any. Answer was no. Just sayin.
Jeff Teuton 4022 STK |
As far as I know all the GM 2 port throttle bodies are more of less the same spec. The publish size is in the blue print specs. Some of the TB have slightly different throttle attachments.
Liked 780 Times in 194 Posts
There are generally only two TBI sizes. One is a 1 11/16" bore that is used on 4.2, 5.0 and 5.7 engines and the other is a 2" bore used on 454 engines.
Sorry! I pulled the trigger to quickly. I thought you were talking about TBI engines.
![]() Last edited by Dwight Southerland; 08-08-2015 at 12:14 PM. Reason: Mistake |
Liked 439 Times in 69 Posts
The spec sheet does not list a part number, all it has is N/A. In the notes it says 2 @ 1.889 48MM, so I guess you can build your own throttle body just make sure its 48MM
Herbie Null 201 SS |
