Old 07-31-2015, 11:44 AM   #9
pbp1
Liked 27 Times in 6 Posts
Default Re: A/F Ratio
No matter where you have the sensor mounted, the two step is skewing your readings. Misfires are always read as lean on the O2 sensor. I dont know exctly why but they do. What has helped me the most is looking at what the A/F ratio does immediately after you let go of the button. If it dives really rich, that tells you it was rich when it was on the 2 step. If it stays lean after you let go of the button, it was lean on the 2 step.
pbp1 is offline   Reply With Quote
