Liked 18 Times in 4 Posts
I'm running a 97 LT1 Firebird in stock. If I was to run Superstock how well would a stocker chassis work with a transbrake on 9" radial tires? Anybody out there doing this? Thanks Tony
#2 | |
Liked 503 Times in 131 Posts
You would need to likely make a few changes if you go the transbrake route as you obviously would be going from loaded chassis to unloaded at launch. 9 inch radial tires might prove problematic for a transbrake hit, just like they are for stick cars. Eric
Eric Merryfield 1883 STK |
Liked 67 Times in 27 Posts
I run my Drag Pak in Super Stock, 9" radial tire and a transbrake. No issues with my car.
Dennis Breeden |
Liked 6 Times in 4 Posts
I run a 9" radial tire and a transbrake. No problem if the track is "preped" ....
Liked 229 Times in 71 Posts
My concern would be spinning on a marginal track. If you are running a heavier class in SS (such as SS/KA with this combo), I feel like they would probably work because you have the ability to move a bunch of weight around.
