Old 07-29-2015, 05:11 PM   #1
Dragsinger
Liked 99 Times in 60 Posts
Default Re: Dissapointing results switching to 7" converter
Kevin,
I just when through the discovery process of 7" vs 8" with the Super 10. My final decision came after talking at length with Gary Hettler and Charlie Plott with ATI.
ATI built me a high stall, mechanical diode 8" converter that is the cat's meow
Larry Woodfin 471W
Old 07-29-2015, 09:52 PM   #2
Ed Wright
Ed Wright's Avatar
I have two friends that went to 7" converters in their SS/GT carbureted cars. Already fast, sorted out cars. Both picked up everywhere. I decided I had to have one of those!
Two 7" iterations later, my 8" ATI was still quicker and faster. Depends on the combo, like many other things. Or, I'm doing something very wrong. A strong possibility. LOL
LT1 SS car, 3 speed.
Ed Wright 4156 SS/JA
Old 07-30-2015, 04:41 PM   #3
Kevin Panzino
Kevin Panzino's Avatar
Liked 747 Times in 136 Posts
Thanks for all the replays guys. We seem to be seeing a pattern here.
Hopefully the converter supplier will work with me on exchanging it for an 8"....I would certainly hope so since he recommended the 7"....
Old 07-30-2015, 06:13 PM   #4
S/ST 3040
S/ST 3040's Avatar
Could race weight and RPM range of the two examples be factors in the 7" converters working? Thanks
S/ST 3040 is offline   Reply With Quote
Old 07-30-2015, 07:04 PM   #5
FED 387
Liked 333 Times in 180 Posts
7 inch convertor typical stall is in the 6000-9000 RPM range
8 inch convertor typical stall is in the 4000-7000 RPM range
Where is your peak power? If its in the lower end of those ranges a 7 will not help you
Old 08-01-2015, 07:46 PM   #6
Ed Wright
Ed Wright's Avatar
I'm thinking so. Both lighter cars, both with Quadrajets, both rev higher than mine.
