Old 07-28-2015, 07:44 PM   #3
Jim Caughlin
Liked 805 Times in 245 Posts
Default Re: light front brakes for the Super 10
Sean,
Had the same problem, Strange brakes front and rear, the fronts would hold a small amount of residual pressure after pumping the brake pedal. You could crack the bleeders and a small amount of fluid would squirt out and then they would spin free. I swapped the brake lines front to rear and the problem switched to the rear brakes. I changed to a new duplicate size Strange master cylinder and the problem was solved. I disassembled the problem master cylinder but was never able to figure out why it was holding pressure.
Jim C
SS 6019
Jim Caughlin is online now   Reply With Quote
