Over the years I worked in a transmission shop in Nashville, I worked mainly on racing transmissions, and in around 90% of the Super Stock cars, a foot brake transmission was always measurably quicker, consistently. We even built identical transmissions, except for the valvebody, and in nearly every case, the foot brake setup went quicker, regardless of how the chassis was adjusted, even in 4 link cars. We also tried changing rear end gears and low gears in the transmissions, as well as torque converters. In many cases, I think it may be that the engine is happier with the RPM held well below the flash speed, so that the converter flashes hard/higher and does a better job of multiplying torque. Also, a torque converter really needs to be built for the way you intend to use it, either with a transbrake, or foot braking.
I think the modified cars, and maybe some others with high RPM small displacement engines that need a very high stall speed may be quicker with a transbrake, if the car can be adjusted for it, simply due to how hard it is to make the converter work well. I know they are easier to drive well with a transbrake.
Alan Roehrich 212A G/S |
Liked 57 Times in 33 Posts
Bobby I agree with Alan. (yes I know Alan, it is hard to believe). On a side note tho, I will say that I believe you have to take every variable into consideration. Like my car with the Cleveland, it likes to leave off the two-step (haven't tried a transbrake yet).
Duane Eiskant 1354 Stock/Super Stock |
Liked 373 Times in 131 Posts
I have never drove a transbrake car, but does the t.b. preload the car's suspension like foot braking does ?
Or is the suspension relaxed while on the brake ?
Alan Mackin Stock 3777/ SS 3377 P/SA & SS/PA Fox Thunderbird I/PS '95 Mustang GT |
OK.
I can see where the footbrake might be quicker (e.t. wise) than the t.b. then.
Depends on the combo. Mine is faster off the trans brake. About a tenth.
Ed Wright 4156 SS/JA |
Liked 778 Times in 142 Posts
My car has always been faster footbraking from an idle than transbrake off the two step (~3,000 rpm). But mine is a carburated combo. I've always chalked the difference up to all the nasty raw fuel flowing through the manifold, ports and cyls while the throttle was wide open and the car was at only 3,000 rpm coughing and barking on the two step. then when you let the button go there is a period of time where its very rich until all that mess cleans up. Now that I have a logger, sure enough the O2 graphs show this exact thing to be the case.
I suspect the guys with fuel injection don't have the same problem, since when you are on the two step, the program is also limiting fuel as well???? |
#8 | |
Liked 4 Times in 4 Posts
Alan, When you say the footbrake was quicker, do you mean footbraking while leaning on the convertor or launching from an idle? JimR
Jim Rountree |
#9 | |
It is extremely important to note that I'm talking about a very well tuned car, if you have a car you just can't get to rev up or flash quick and clean, it's not going to run well foot braking.
Don't forget the rollout difference when comparing your ET's.
If the transbrake launch is picking the fronts straight up out of the beams rather than getting the run at it rolling out, it could be a .03-.05 difference. |
