Old 07-19-2015, 11:20 PM   #10
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Default Re: trans temp sender location
The problem with too much converter charge pressure is it will lead to a ballooned converter, and also pushes hard on the crankshaft, which could lead to crankshaft thrust bearing problems. Converter charge pressure is usually limited to around 100 psi.
