Old 06-30-2015, 06:51 PM   #1
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: 75 Nova U/SA
All 307s use the small base 2G. Just like a 283. OBTW, I think that you're right about the 262. It should run much better than a 307.
SO, the 305 with 43 more cubic inches, a bit better camshaft, and a bigger venturi carb, is it better than the 262 even though it costs 15 hp?
(Not mentioning the nice heads on the 305)
Old 06-30-2015, 07:09 PM   #2
Billy Nees
Liked 7,731 Times in 1,739 Posts
The 305 and 262 heads are basically the same. AND the 76 262 gets the same carb as the 305! Only problem is the availability in the Monza only. I personally think that the 305 is a better deal but then, I'm the guy that did a 307!
Billy Nees 1188 STK, SS
