Old 06-25-2015, 07:52 PM   #14
JohnRoderick
JohnRoderick's Avatar
Liked 11 Times in 4 Posts
Default Re: Bellhousing alignment issue
Originally Posted by Mike Taylor 3601 View Post
I can't remember the size and don't have any on hand at the moment,but I think the size your holes in your block are the size that they opened up to when using BHJ products fixture.
BHJ dowel true corrects dowel holes off main bores,reams holes oversize to correct position.
I always use weld on bushings,easiest way to correct,I also use BHJ dowel true and surface bell area of block square to mains.
Mike Taylor 3601
Mike,
You hit the nail right on the head. I was able to confirm that dowel pins where setup with the BHJ dowel true. Now I need to figure out the source of the 0.014 offset.
Thanks,
John
JohnRoderick is offline   Reply With Quote
