Old 06-20-2015, 03:40 PM   #1
Dean Feiock
Dean Feiock's Avatar
Liked 49 Times in 15 Posts
Default Re: Ford and Dodge truck tech's - question
Originally Posted by Alan Roehrich View Post
I'll stick to my 2003 8.1L gasoline powered 3500. I saved well over $5K by going gasoline, I have plenty of power, get decent fuel mileage, and should anything go wrong, my 8.1L costs about 20% as much to repair as any "new" diesel. And it is far easier to work on as well.
Alan,
I used to think that way also when I towed with my 2003 Ram with an 8.0 liter V10. But when you go from the 6-7 MPG it got to the 13-14 the 5.9 gets towing 20,000 lbs, it will change your opinion fast. Not to mention the real towing power that a diesel with a turbo will give you.
Not sure how you can fix any gas engine for 1/5th of the cost of fixing a diesel engine.
And yes, you may have saved $5 buying your truck, but it will show in the resale. Diesel's hold their value far better than a gas powered truck.
Dean Feiock -- Stock 5002
Dean Feiock is offline   Reply With Quote
Old 06-20-2015, 04:26 PM   #2
Philip Saran
Liked 14 Times in 11 Posts
As a former owner of a Ford 6.0 diesel in a 2004 F350 I will also concur, stay away.
before I sold it off my service mgr. at the dealer said if I wanted to upgrade only buy
a 2011 or newer Ford 6.7.
I ended up with a class A motorhome with a V10.
Phil Saran
Parker, Colorado
Philip Saran is offline   Reply With Quote
Old 06-20-2015, 08:46 PM   #3
Liked 1,912 Times in 429 Posts
Originally Posted by Dean Feiock View Post
Alan,
My truck gets a lot more than 6MPG towing. Around 10, actually. It has enough power to tow at 70MPH plus. I haven't even started tweaking it. An Ed Wright tune will help that. As will some other work.
Priced a set of injectors for a diesel vs a set for a gasoline V8 lately? Or an injector pump?
I'm not interested in selling it. You can't buy a new one like it.
To each his own. I'll keep my gasoline big block V8.
Old 06-20-2015, 10:49 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,227 Times in 981 Posts
Dean is right on, my 2007 5.9 was the best truck I've ever owned, fortunately I can still use my son's 2006 5.9 which is just as rock solid as my truck. We're currently pulling our RV around out west with the wife's Mercedes diesel and it does equally well with a huge plus that most places out here diesel is less than regular gas, sometimes by as much as 20 cents cheaper.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
