Old 06-02-2015, 08:52 PM   #31
Peter Ash
Peter Ash's Avatar
Default Re: Broken Torque Converter
deleted
Peter Ash 6100 STK
Peter Ash is offline   Reply With Quote
Old 06-03-2015, 07:19 AM   #32
ss wannabee
Liked 7 Times in 7 Posts
Greg...were you trying to make E-town for class? Can you switch to the Stocker until the Mirada is ironed out?
ss wannabee is offline   Reply With Quote
Old 06-03-2015, 08:38 AM   #33
Dwight Southerland
Dwight Southerland's Avatar
Liked 772 Times in 192 Posts
Originally Posted by Greg Gay View Post
Seriously, I would like to drive a stick. Even though the transmissions are much more reliable, due to the fact that you set the clutches up so softly today, I thought the slippage required continual adjustment. I will say "Someday, maybe."
If you want to run on kill, that fine line of pre-slippage is what everybody talks about. However, if you want to go rounds, you do not have to run it there. There is less than .05 difference between the "kill" setting and the soft setting that allows you to go 5-7 rounds consistently without having to readjust. Material of the discs makes a difference, too. Buy from knowledgeable vendors who will help and keep a good log book.
Old 06-07-2015, 07:52 PM   #34
Greg Gay
Liked 283 Times in 70 Posts
The converter was the problem. ATI supplied me with a new converter. I had to fly it in to get it for Friday. Still, from faxing in an order on Sunday to them shipping it on Thursday seemed like pretty fast service. And they were swamped with business. I think being a Classracer helped.
Next question: Is the broken converter worth keeping for any reason, or should I just throw it in the scrap iron? It isn't really correct for my current applications, but you never know. Or is it better to just start from scratch once one is broken?
Clutch question: So, is "fast" set up tighter or looser than "bracket mode". If you have to adjust it every 5 to 7 runs, how long will it last? Most of this is just for curiosity.
Greg Gay is offline   Reply With Quote
Old 06-07-2015, 08:38 PM   #35
MR DERBY CITY
Liked 7,800 Times in 1,499 Posts
Hey Teddy yacavone, it was the converter after all..IMAGINE THAT....LOL....M.J.
MR DERBY CITY is online now   Reply With Quote
Old 06-07-2015, 08:42 PM   #36
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Greg,
Loose is fast, but also on the edge of sliding it too much and glazing the disc. That requires disassembly and knocking the glaze off the disc. Adjusting a clutch with the right bellhousing can be accomplished in less than 10 min. It takes longer to get the car in the air. You also do not have to adjust the clutch that often, in my experience. I have over 200 passes on my clutch and have yet to have it serviced. Every off season I pull it and check everything and bead blast the discs to clean it. It is then that the discs and pressure plate are checked for how much material has been lost on the disc, and the pressure plate is shimmed to accommodate the disc wear, if needed. There is a little bit more to this but that kind of narrows it down.
Sean
Sean Marconette
84 Mustang
5060 SS/N
Old 06-07-2015, 09:24 PM   #37
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Broken Torque Converter
Greg,
Always , keep it for a spare ? Have it set-up close to what you are running now... If you had a good spare, you won't have been down for as long as you were ? A good core is worth $ 2-300 & most Convertor guys can do wonders with broken ones ..... Hope all is well & Good Luck @ NED ....
Dave Ribeiro 1033 STK
