CAUTION... I have cut several pairs of Moroso springs over the years. Good springs for the price and work much better than stock. BUT they always settle a little with some use. Leave them a little longer - read sitting higher, than you want for final. 1/2 - 3/4" inch higher than what you want for final static height.
Know it is a pain in the butt to pull them out and cut a little and put back, but you can not add coils back if you cut too much. Also, never use a torch to cut. Saw or cutoff wheel. Heat from torch will kill them. Be careful and good luck. Ken Stock 412 |
