Liked 20 Times in 15 Posts
I am putting together a /6 2BBL. Looking in the NHRA guide they list 3 intake manifolds for the 1980/6 2 BBL The one in question is 4095223. This # is also listed for a '78 /6. I found an alternate manifold from 1978, 4041043, which is legal for '78. Since the 223 is accepted for 78 and 80, can I also use the other 1978 alternates?
I doubt it. Which year are you running? As for manifolds, there's not any real diff in performance between them. I think Philip Marvetz did a back to back test and found no diff in perf.
Liked 2,486 Times in 697 Posts
x2 Phillip would know.
I just looked at the guide and those were the part #'s listed. Can I just substitute any factory 2BBL intake manifold or will I get bumped on the tech side?
Liked 780 Times in 194 Posts
You can only use the numbers listed in the Tech Bulletin for the year, displacement, hp engine you claim to be racing.
#6 | |
Liked 172 Times in 81 Posts
Jim Mantle V/SA 6632 |
