Old 05-21-2015, 11:43 AM   #1
Jim Carter
Liked 19 Times in 3 Posts
Smile Seat Weight
Does anyone have a close approximate weight of a bench front seat for 68-69 GM A- bodies?
Thanks.
Jim
Jim Carter is offline   Reply With Quote
Old 05-21-2015, 12:09 PM   #2
Mark Faul
Liked 43 Times in 9 Posts
Default Re: Seat Weight
Thanks.
Jim
FWIW, the bench seat in my 66 elCamino weighs 70lbs. Never weighed the bench in my old 69 Chevelle.
Mark Faul is offline   Reply With Quote
Old 05-21-2015, 12:23 PM   #3
Jim Carter
Thumbs up Re: Seat Weight
Thanks Mark. I would think they are very close. Trying to see if swapping to race seats is worth the expense for the gain in weight shifting.
Old 05-21-2015, 01:47 PM   #4
Danny Ashley
Liked 110 Times in 29 Posts
Jim:
Here's the individual weights of the bench seat out of my 1971 T-37 A-Body. Had it re-covered before the stupid aluminum seat rule so I haven't put it back together.
1. Bottom = 39.4 lbs.
2. 2 backs @ 18.4 ea. = 36.8 lbs.
3. 2 head rests @ 3.2 ea. = 6.4 lbs.
Total = 82.6 lbs.
As you might guess I don't like the rule but I've spent a lot of time in other areas to rid weight and it would be foolish for me not to put them in. I'm not sure how much the seats will weigh when installed but maybe someone can tell us. I'm guessing that a savings of around 40-50 lbs. Hope this helps. Regards, Danny
Danny Ashley is offline   Reply With Quote
Old 05-21-2015, 03:40 PM   #5
GTX JOHN
Liked 2,486 Times in 697 Posts
Hi Jim:
Our A Body Mopars saved about 45 lbs over stock
buckets....Hate the look and idea of it but that is a HUGE
weight loss!!!!!!
Hope to see you this year my Friend!
John Irving
741 Stock
741 Super Stock
Old 05-21-2015, 07:53 PM   #6
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
soooo,whats the average kirkey weigh?
Old 05-21-2015, 09:07 PM   #7
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
The Model 41500 weighs 12.1 pounds.
Wasn't the original idea behind the rules change because the newer seats were "safer"?
https://www.kirkeyracing.com/related...op-drawing.jpg
Lew Silverman #2070
"The Wagon Master" N/SA
Old 05-22-2015, 01:25 AM   #8
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Yes, but they look like hell with the lid off in most older cars...not so bad in the late models.
Rich Taylor
I/SA - 321
Old 05-23-2015, 03:59 PM   #9
Jim Carter
Smile Re: Seat Weight
Lew:
Does that include the weight of the mounting rails, hardware and covering?
Old 05-22-2015, 08:28 PM   #10
Run to Rund
Liked 54 Times in 27 Posts
66 Olds F85 front bench weighs 74 lb.
