Go Back   CLASS RACER FORUM > Class Racer Forums > Factory Stock and Super Stock
Old 05-04-2015, 02:47 PM   #1
rognelson777
Liked 135 Times in 74 Posts
Default Re: Boost Monitoring?
Interesting conversation, but you cannot just single out boost as a separate item, a supercharger is a engine component, just like a camshaft is and boost is a function of a operating engine.
If you change a camshaft (in stock IE change duration) and the engine can rev higher it can build more boost and just like every other component has limits.
I try to relate it this way, years ago the key was to put the biggest carb on a car you could, but if not matched to the combo, to large was really worthless.
rognelson777 is offline   Reply With Quote
