Old 04-24-2015, 09:41 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: LT-1 Heads
Originally Posted by casrak7 View Post
Hi Ed......Could you send me pics of this also? Thankyou much!
Get the second picture too?
Ed Wright 4156 SS/JA
Old 04-24-2015, 10:07 PM   #2
casrak7
Liked 3 Times in 2 Posts
yes....those attach to the lower radiator hose? where do i get such a fitting?
casrak7 is offline   Reply With Quote
Old 04-24-2015, 11:05 PM   #3
Ed Wright
Ed Wright's Avatar
Upper hose, which is on the driver's side. Lower hose, from the water pump, goes to the bottom of the passenger side of the radiator. I Tig welded mine together from a piece of 1 1/2" exhaust tubing, a piece of steel plate to cap off one end, and steel -10 AN fittings Tig welded to it. Those two -6 fittings on top, that are capped, are not needed.
Old 04-26-2015, 08:21 AM   #4
Lee Valentine
Liked 319 Times in 68 Posts
Did mine like Ed did his,works fine.
Lee Valentine 1661 STK
Old 04-26-2015, 09:54 AM   #5
Ed Wright
Ed Wright's Avatar
Lee, Sheep Boy found some slick push button bleeders for the back of the cylinder heads to get the air out. He either told me where to find them, or just handed me a pair. A few years ago, and I forgot. I top mine off, turn the water pump on, and reach Bach there and push the button on each side until water comes out. Then top the radiator off again. Works really slick. I will try to find out where to get them. They are 1/8" pipe thread. I put them in the 1/4" pipe thread holes already there.
Old 04-26-2015, 10:09 AM   #6
Lee Valentine
We have them at work,good idea. They are bleeders for roots type superchargers
Old 04-26-2015, 10:13 AM   #7
Ed Wright
Ed Wright's Avatar
Makes getting all the air out quicker.
