Old 03-27-2015, 03:31 PM   #1
gbur
Default 2001 Camaro driveshaft
Anyone had issues wiih vibration above 5000 rpm in 3rd, seemingly shaft is too short ?
Gary Burr IHRA MEMBER # 1958 Stk 1949
gbur is offline   Reply With Quote
Old 03-27-2015, 03:54 PM   #2
Rob Petrie E395
Liked 216 Times in 77 Posts
Default Re: 2001 Camaro driveshaft
Yes there are several GM bulletins on it. And the problem only gets worse if you put a numerically higher than factory rear gear ratio in it. I'm assuming here that you are talking about a GM drive shaft. In my street cars I put 1LE driveshafts in them. I have them rebalanced as well. They don't have the heavy trans Yoke with the balancer on them which makes them easy to spot in a salvage yard if you are looking. Can find them on Ebay too but usually priced like Gold there. . On both my racecars I put aftermarket shafts in them.
Old 03-27-2015, 05:47 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
The 1LE driveshaft is aluminum, which dampens out those vibrations. It was a service fix for awhile. Watch out though, if you drop the clutch with high traction tires, it may twist up like a pretzel !
Old 03-27-2015, 05:50 PM   #4
gbur
4L60E here
Old 03-27-2015, 11:17 PM   #5
ss3011
ss3011's Avatar
I think the 4L60, and the manual trans, uses the same driveshaft.
Old 03-28-2015, 01:03 AM   #6
gbur
that is what all references say
Old 03-28-2015, 07:58 AM   #7
Cdncarnut
Cdncarnut's Avatar
Liked 56 Times in 31 Posts
I bracket raced a stock 2000 SS Convertible, with a manual transmission, for the last 3 years and did not have any vibration issues. even when going to through the lights, at the top end of the track, just shy of the built in rev limiter, in third gear.
The factory driveshaft is aluminum in my car.
Thomas
NHRA 1959 E/SA
Cdncarnut is offline   Reply With Quote
