Old 03-21-2015, 07:05 PM   #11
ATI Performance Products
Sponsor
ATI Performance Products's Avatar
Liked 9 Times in 1 Post
Default Re: Which rear end would I be better off with?
Originally Posted by GTX JOHN View Post
We have run 8 3/4 in our Volare / Aspen Stockers for many years with only
a couple of Failures in the Very Heavy Wagon at 3620 to 3850 Weight.
I would consider a looser converter 5200 (360) - 5400(318) to go with the 5:13 Gears which should be right a low elevation.
My Chassis guy said with same amount of lightning the Dana would be
40 to 50 heavier than 8 3/4. Does anyone know if he is right?
We are changing the Challenger over to a Dana right now. I need to run a 5.13 at our weight and the 8 3/4 would ratio would break in less than 10 passes. But a 4.88 would last 100 passes usually. We are 3470 lbs. And yes it sucks to break a gear with a 904 and then worry about the sprag - even with the big sprag we made for them it was 50/50 weather or not it was junked. - Also of note is that I will have 4, nice 8 3/4 pumpkins to sell! 2 Alum and 2 steel.
ATI Racing
ATI Performance Products is offline   Reply With Quote
Old 03-22-2015, 12:09 AM   #12
LNorton
LNorton's Avatar
Liked 4 Times in 2 Posts
^ This! Go Dana and forget about it.
Lee Norton - N229 STK
IHRA H/FIA - NHRA O/SA
RacerTees.com
LNorton is offline   Reply With Quote
Old 03-23-2015, 05:34 AM   #13
SST3193
Liked 2 Times in 2 Posts
Any Dana experts have a suggestion, for a 1976 Ford housing, that houses 3.50:1 only? We built a 4-linked street car for a friend and would like to have a 4.10-ish range ratio. With the tall rear tires and 3.5 it sure does good on the Interstate but rarely leaves city streets.
SST3193 is offline   Reply With Quote
Old 03-23-2015, 07:13 AM   #14
GTX JOHN
Liked 2,487 Times in 698 Posts
I did not know their are 4 different weight Dana 60s. Does know how to tell
them apart. The ones I have used are center sections out of 80s Trucks
with Chrome Moly Tubes.
John Irving
741 Stock
741 Super Stock
Old 03-23-2015, 12:07 PM   #15
FED 387
Liked 333 Times in 180 Posts
no expert here but from my experience there is a HD cast into the housing look for it top of rib left side of the "heaviest" Dana 60 ,otherwise the diameter of the axle tubes determines the lightness of the housing with 3 inch tubes being the heaviest---the OEM centers are really the same---supposedly there is a "501" Ford Dana 60 that is the lightest but I do not know what vehicles it came in--FED 387
Old 03-23-2015, 01:38 PM   #16
Michael K
Liked 62 Times in 17 Posts
I've been considering replacing my 8-3/4 with the Strange 60 housing. Pricing seems good.
Michael K is offline   Reply With Quote
Old 03-23-2015, 02:15 PM   #17
older racer
Liked 68 Times in 26 Posts
hi, the four dana 60's are, lightest is in a 67 to 72 ford 1/2on pickup, next is mopar b and e body cars, next 3/4 ton pickups and heaviest is 1 ton pickups. I found an article in a four wheeler magazine years ago. they listed the dana's . the 1/2 ton ford one has passenger car ends on it, easy to spot. it weighs 32 # more than 8 3/4 . has 3 " tubes. also, I found a dana 60 from a J 20 jeep pickup. it has 2 3/4" tubes on it , passenger car ends as well.
older racer is offline   Reply With Quote
Old 03-23-2015, 05:50 PM   #18
Rod Greene
Liked 242 Times in 81 Posts
If you are building one for a race car. Do it the right way. Strange S60 center molly tubes, 40 spline ultra lite axles from MW Aluminum spool back cut ring gear. It will be bullet proof and only about 20lbs heavier than a back braced ready to run 8 3/4 that will break anyway. If you are worried about changing gear ratios at a race it is really quite simple. With the S60 you have adjusters for back lashand preload. You set your pinion gear up with bearings and shims. You can change gears in under an hour.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
