Old 03-20-2015, 04:17 AM   #4
Rod Greene
Liked 242 Times in 81 Posts
Thumbs up Re: Which rear end would I be better off with?
Dana 60 all the way. The dana I had in my car was only 20lbs heavier than the 8 3/4. It is bullet proof and takes less HP to rotate. It is a no brainer. If you run an auto if you break the rearend it takes the tranny with it. Just one more reason for Dana.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects.
Rod Greene is offline   Reply With Quote
