Old 02-23-2015, 01:24 AM   #12
pbp1
Liked 27 Times in 6 Posts
Default Re: Ring and pinion set up question
If the pattern comes to a point on the root side, you need to pull the pinion farther away from the ring gear, which in this case would mean removing some pinion shim. That being said, removing shim would move you outside the normal range on shim. I would make sure that the inner pinion race is fully seated in the housing bore as this would give you a false reading.
pbp1 is offline   Reply With Quote
