01-23-2015, 06:10 AM | #1 |
SBF main bearings?
Are the P's any or much better than standard? What do most of you ford guys use on your builds and also rod bearings also? 331 ci !
Thanks1 |
01-23-2015, 10:52 AM | #2 |
Liked 116 Times in 48 Posts
Re: SBF main bearings?
There is A-series bearings which are aluminum bored,didn't like them when they were introduced,but I take engines apart with them all time with 100K+ and they still look good, these are shiny bearings like come in all late model engines.
P-series is tin plated that has been around for years H-series is high performance. I usually use H series bearings most any thing I do street/strip,if you have a forged crank you have to use H series to clear larger radius on crank, H bearings are narrowed or chamfered to clear. I have been using alot of King bearings last few years. You can have good results with about any bearing,if have clearances correct,clean assembly, no oiling problems. |
01-23-2015, 09:50 PM | #3 | |
Liked 18 Times in 12 Posts
Speed Pro 129M series are Competition main bearings, also available Coated. Speed Pro 8-7160CH are the rod bearings, also available Coated.
"Real Race Cars Have Tailgates" |
01-24-2015, 12:27 AM | #4 |
Thanks!
01-27-2015, 11:02 AM | #5 |
Liked 260 Times in 112 Posts
You might want to check the journal size on the rods - quite often the rods require a 2.100 bearing, common SBC bearings are too wide, they take a narrow 2.100 bearing such as 229CI GM v-6 - Clevite 1227P or H, or the Federal Mogul equivalent. Once in a while the stroker kits will come with the 2.000 rod journal also.
Phil Molski PMR Performance S/C 1623 |
