Old 01-18-2015, 05:22 AM   #1
Bobby Zlatkin
Bobby Zlatkin's Avatar
Default Carter WCFB or Rochester 4GC?
Which works better for a 283?
Just curious.
Bobby & Norene Zlatkin L/SA
Bobby Zlatkin is offline   Reply With Quote
Old 01-18-2015, 08:43 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Carter WCFB or Rochester 4GC?
My old 250 hp 327" was a good bit faster with a 4GC.
Ed Wright 4156 SS/JA
Old 01-18-2015, 10:05 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Yes.
Dwight Southerland is online now   Reply With Quote
Old 01-18-2015, 10:27 AM   #4
Bill Belden
Bill Belden's Avatar
Ditto
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
Old 01-18-2015, 12:12 PM   #5
james schaechter
Liked 1,437 Times in 300 Posts
Especially if you race a stick in stock! Dean Oliver can do wonders with these carbs! The 4gc is a small, but very reliable carb to race with too. We have used them on our 283s and 327 250 hp combos for years. The wcfb was a lot more picky about fuel control on the launch for stocker stick cars anyway.
James Schaechter 3163 STK
james schaechter is online now   Reply With Quote
Old 01-19-2015, 04:50 AM   #6
Bobby Zlatkin
Thanks guys. That makes it unanimous.
I wonder why Chev chose to go with Carters for their 2 four set-ups (245/270 HP)?
Probably because back then, for them, there was no difference or it was negligible.
Old 01-19-2015, 11:48 AM   #7
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: Carter WCFB or Rochester 4GC?
When looking for rebuildable cores for either a WCFB or a 4 jet, keep in mind there are different sizes of both. The 265 and 283 up to at least 1961 used a smaller carb than the 64-66 283. The 250 horse 348 used a bigger 4 jet, that was carried over to the 62-65 327 250 horse,and the 64-66 283 as well. A local racer was looking for a WCFB for a '55 he was starting to build,and I had one from a 65 327 that I once owned, (the only part I still have from that car),and it was considerably larger than the 265 unit. The 63-65 340 horse 409 used a large 4 jet,but it differed externally enough to be very obvious. Just be sure you get the right unit. If you plan on racing a 65 327, let's say, and inadvertently got a '60-61 283 carb on it, that could be the reason it's not real fast.
