#1 | |
Liked 1,568 Times in 579 Posts
I have a similar question about this although the motor I'm working on is Chev. The rulebook refers to design pattern , surely the valve notches could be figured into the dish CC s ? ---Trevor
Liked 124 Times in 39 Posts
A dish could be 40 holes drilled in the piston. Unlike stock, the piston just need to be measured legally for some kind of dish.
Sean Cour T6066 ladle |
#4 | |
"Replacement pistons permitted, provided they do not increase stock compression ratio and retain overall design pattern as specified by automobile manufacturer. Dish pistons must retain half of original depth, and original diameter and configuration." That is to say, yes you need to keep the original dish design. And you need to keep at least half the original depth. The remaining CC lost by a shallower dish can be acquired by valve reliefs. |
