Old 01-07-2015, 05:15 PM   #25
a pontiac
Liked 36 Times in 11 Posts
Default Re: Update E-F/SA Bird Build...
while the cam is swapped out, check ring drag with torque wrench on crank. getting to 11lb. helped mine. some are a lot lower, but with vac-u-pan setups. higher spring press. needs 3/8 pushrods, 4-4 1/2 qts. in the oil pan helps. Be sure you are getting max. legal valve lift.
a pontiac is offline   Reply With Quote
