Old 01-05-2015, 10:08 PM   #5
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: Valve guide & spring seats on Stock heads.
I don't think removing the inner step is a problem, they don't want to see grossly oversize springs. The step is typically about .100" deep and before you remove it, see if it works to your advantage as coil bind won't be a problem with a stock cam lift.
Paul Precht is online now   Reply With Quote
