Liked 346 Times in 126 Posts
I don't want to run a fuel cell, so I am looking for someone who can modify my stock pickup to an AN fitting also maybe incrse the size of the pickup.
TIA Dave |
Liked 6 Times in 4 Posts
A good radiator shop can do that mod....
Liked 1,572 Times in 580 Posts
You can remove the original pickup and drill it for an AN bulkhead fitting. Then use aluminum tube with AN tube fittings for your pickup.
Check out these site for ideas. http://www.cowboyplayground.com/public/dp.htm http://para.noid.org/~lj/Fuel/fuelfor600.htm Last edited by SSDiv6; 10-30-2007 at 04:01 PM. |
Dave,
take the sending unit out and cut off the fuel lines on both sides, then drill it out for a bulkhead fitting either # 6 or # 8 depending what size line you want. Use steel tubing to replace the inside line, flare the end and secure it using a tube nut.
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
In lieu of steel tubing, I would recommend the use of aircraft aluminum tubing. Does not corrode, lighter and absorbs vibration and harmonics without breaking at the fitting.
Liked 772 Times in 192 Posts
I have also used copper tubing bent to shape and soldered in place through the flange for the pickup tube. I believe GM solders the steel tubing in place from the factory. You can even solder the float sending unit onto the copper tube and have the stock fuel gauge work.
#7 | |
Dave |
