Old 12-31-2014, 04:20 PM   #1
goinbroke2
Liked 405 Times in 158 Posts
Default Re: Moby Vic!!!!
Same carb(1.21)/valves(2.06)/intake and lift is like .406 to .428 compared to the 351M so I think it'd be better.
Old 12-31-2014, 05:18 PM   #2
There ya go...351M, as a Landau..U/SA!
Old 12-31-2014, 07:56 PM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
351 blueprints under 9:1 compression; 400 is 9.7. 50 more cubic inches.
Old 01-01-2015, 12:33 AM   #4
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
OK. Both the 351M & 400M use the same size 2bbl (1.686/1.21 ) the same heads with the same valves. The 351 has a little over 8 1/2:1 compression & the 400M a little under 9 1/4:1. Yeah the cams are different but with what cam grinders can do these days, I think that's pretty much a wash. (probably wrong).
The 75 & 74 460"s The valves, cams are the same the compression's are similar But as Billy reminded us:
Ya know, I really have to ask, how is this combo bogus? All but the 74 can only use the small Motorcraft 4350 carb(700 cfm?)..
& It seems Mr.Graham does pretty well with the combo in Super Stock
[IMG] [/IMG]
Dave Noll, EF/S ,?/SA 6526
Old 01-01-2015, 02:50 AM   #5
goinbroke2
351vs400 I just figure with the same top end the smaller cubes it's got to be fed better. Same as a 302 is ok but the 351W is a pig cause it uses the same head/valves.
50 cubes in that case is a detriment not a bonus.
A point in compression is obviously nothing to sneeze at either, but there are more factors in the 351's favour than the 400's.
The 460 is just cool regardless
Old 01-04-2015, 05:23 PM   #6
vic guilmino
Liked 56 Times in 21 Posts
piston in block
Vic Guilmino 1129 STK
Old 01-07-2015, 04:45 PM   #7
stock1080
Liked 94 Times in 38 Posts
anyone notice the wing on that gt/fa car....I'm no ford expert but? also I have a
1979 ranchero..wonder how that would hook up with a 460...
stock1080 is offline   Reply With Quote
