Can you use new ones on a cam that ran standard lifters?
Number for Sherman...or??
Liked 308 Times in 103 Posts
Mark,
As long as your lobes still have taper left on them and lifters are crowned .001-.0015 should be fine.I have been using precision performance products from NC.also heard good about Trend products, I have a set of Johnson haven't tried yet,that are high carbide content on bottoms, they are solids i will have to modify to have.015 travel Mike Taylor 3601 |
#3 | |
Liked 4 Times in 3 Posts
P.O. Box 1326 Donaldsonville, LA 70346 (225)473-4923, (225)717-1460, (225)717-1461 shermanracing@bellsouth.net
Kenny Miracle P/SA 310 |
Liked 880 Times in 311 Posts
Mike, I have several sets of PPPC coated bottom solids that I've used as modified travel lifters. I even have some that are just the lifter bodies. They are the shorter, extra lites. With a little band modification they will work in Pontiac's, too. Since I'm winding down the business I'll make a deal on them.
I like the quality I've always gotten with all PPPC products. 1 800 421 9150 A few years ago I got one of their large Degree wheels... wow, talk about nice. Not a cheap silk screened wheel that can run "Off" on the degrees as you rotate it... It checks right with my digital Cam Pro Plus. Degree for Degree.
Adger Smith (Former SS) Last edited by Adger Smith; 12-17-2014 at 04:29 AM. Reason: sp |
If get a chance Adger send me a PM with what you have.
I use to use 16'' comp cams wheel thought it was nice,then got a CV products24'' wheel really like it, use the comp cams degree wheel sockets,which some need to be replaced,my sbc has play in it have to split the difference. How big is PPPC's wheel? Mike Taylor 3601 |
Part # Description
18000 16" Aluminum Degree Wheel 16" Degree wheel is machined from 1/4" Aluminum. Degree marks are machined approximately 1/8" apart so they’re easy to read. Heavy design allows the builder to rotate the engine while “degreeing” the cam. Comes with 7/16", 1/2" and 5/8" bushings. StarMark by BAASEL Laser Tech is our latest addition of services available to all of our customers. The StarMark Diode is a marker beam source with diode pumped YAG (DPY) lasers—particularly suitable for permanent marking of plastics, metals, and high-tech materials. Ideal for integration in production. Mike, YAG is the same kind of Laser they use in some eye surgeries. I guess if it is good enough for your eyes it is good enough for a Degree wheel..LOL! There are wide tolerances with the Silk Screen type others use. You can't keep the silk screen accurate. http://www.pppcenter.com/
Adger Smith (Former SS) |
my 24'' CV wheel has marks machined into it also,had never thought about the silk screen being off.
Mike Taylor 3601 |
