Old 11-19-2014, 10:38 AM   #1
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
Default intake manifold
The rules say you can't touch it, no mods, but final say so is left to the discretion of the tech director.
As most of you are aware of, its easier to win the lottery jackpot than it is finding an unmolested 45 year old manifold, specifically in my case (D1ZX-9425-DA) and, the ones that do have them....well you can cast it out of solid gold and it would be cheaper than what they want to part with it for.
With that being said, It seems like everybody is an expert at modifying and had to get in there an "notch" or cut away the center divider.
What gives here? minor notching? cut it ? drill holes in it? or leave it as is? I know what the rule says, but what does the tech man say?
How much luck would I have getting an "approved" aftermarket intake to fly as long as it is the same configuration
Bill Diehl is offline   Reply With Quote
Old 11-19-2014, 12:03 PM   #2
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Re: intake manifold
Hey Bill if you want to run a 4300d carb i know were you can get a nice CA intake.
7015 E/SA Sooner Storm
astikhossw is offline   Reply With Quote
Old 11-19-2014, 12:26 PM   #3
Bill Diehl
Bill Diehl's Avatar
The blue thunder is supposed to be a copy, I am going to see what they say about that.
I need the standard holley pattern, I need to use my carb
Old 11-19-2014, 12:56 PM   #4
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
For the Bow Tie and MOPAR folks, he's talking about a BOSS 351 Holley 4bbl intake called a "Buddy Bar". It's a performance specialty part according to MustangTech.com and very hard to find.
Just say No to 4300...
Dale
Old 11-19-2014, 01:32 PM   #5
Lou Jeffery
It should be NO problem to get a manifold accepted for your application. Just like the 502 crate motor gm performance manifold accepted for the 396 375 Chevrolet.
Lou Jeffery is offline   Reply With Quote
Old 11-19-2014, 03:42 PM   #6
SSDiv6
Bill,
The Blue Thunder happens is an identical copy of the D1ZX-9425-DA intake. Will not be surprised if the guys at Blue Thunder purchased the original tooling from Ford like they did for many of their other offerings.
Just submit it to NHRA for approval like many have done for other applications.
