#21 |
I think the response to the question is being misinterpreted....there is a spec for total valve lift and a rocker ratio listed in the spec.....what Bruce said was " the cam lobe lift checked with a solid lifter and the numbers are good you are all set to go ".....in this case your rocker ratio better be correct or you will be bounced, I personally wouldn't mess with taking a chance on that...too expensive of a mistake......
D L Rambo......Stk 1300 |
#22 | |
Liked 5,097 Times in 1,943 Posts
" AS LONG AS THE CAM LIFT, CHECKED WITH A SOLID LIFTER, DOES NOT EXCEED THE SPEC YOU ARE ALL SET "
#23 |
Liked 9 Times in 8 Posts
I wish I could use a .502 lobe on my combo
![]() but the book says "cam lift" and we all know what that means |
