#11 | |
Liked 12 Times in 6 Posts
#12 | |
Liked 1,879 Times in 422 Posts
That's fine. Get it in writing, with the NHRA logo, and some sort of digital signature, and keep it with the car. There needs to be zero doubt that it is the absolute official word from NHRA @ Glendora.
Alan Roehrich 212A G/S |
#13 |
Liked 325 Times in 50 Posts
I got thrown out 3 or 4 years ago for that. Cam checked, but rocker are stamped 1.65 and specs call for 1.60. I'm not sure if the rule has changed.
Jeff Teuton 4022 STK |
#14 |
Liked 10 Times in 6 Posts
When did they go back to using a stock solid lifter to check lift? The last time I set the record they used there adjustable lifter. I think nhra. should sell a adjustable lifter if they are going to check with one. chevy stock solid lifter has different height than a smith lifter. I was told by well known engine builder that with roller rocker arms, longer & shorter push rods don`t change lift, like stock rocker arms. Tom
Tom Moock 5704 STK |
#15 |
Liked 880 Times in 311 Posts
I've been involved in rules as well as in Tech at EMC. We were dealing with the same issue (rocker ratio) at Engine Masters Challenge. I have come to the conclusion the NHRA rule (As written) is not enforceable..I have had the input from a very notable former NHRA Tech person who is on our team and he concurs. That is the reason we have no Rocker Ratio rules at EMC. I think NHRA should re write that rule. I also think it is just asking for trouble to have any stamped ratios on rocker arms. When the wrong person tries to verify the ratio it can come up way wrong. That ratio number being wrong "could" be grounds for action by the NHRA.
Adger Smith (Former SS) Last edited by Adger Smith; 10-24-2014 at 12:45 AM. Reason: sp |
#16 | |
You are going to be allowed to match the overall height of what you're using. Trust me on that.
#17 |
Yes, Mark after the fiasco in Div 4 concerning cam/valve lift I would think proper procedure might be followed a little closer.
Adger Smith (Former SS) |
#18 |
Liked 24 Times in 13 Posts
Direct excerpt from 2014 NHRA rule book:
"ROCKER ARMS OEM or aftermarket rocker arm permitted.Needle/roller bearing pivots and roller tips are permitted for all applications.Must remain same design as original application(i.e. stud mount must retain stud mount, pedestal type must retain pedestal type, and shaft type must retain shaft type. Stud girdles prohibited.) Stamped steel OEM and OEM-type rocker arms may be reinforced." It's obvious what's not mentioned! |
#19 | |
Liked 9 Times in 8 Posts
My 2 cents would be....who cares what any of the numbers are on any of the parts as long as the lift at the valve is within spec. The system can be engineered and designed to function much better and be a lot easier on parts than some of the stuff that's currently in use now, and still remain inside the "lift" rule |
#20 |
[QUOTE=Bill Diehl;450834]The ratio is listed in the blueprint specs
Your right. |
