Old 10-06-2014, 11:46 AM   #1
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: Bad racing fuel ?????
With Sunoco becoming the official fuel of NHRA, there should be less issues with fuel check and it should be available at the track as well. But they do have an extensive distribution network if you want to get it before a race.
http://www.nhra.com/story/2014/5/5/s...icial-sponsor/
http://racegas.com/fuelfinder
LOCOMOTION Racing
Old 10-06-2014, 01:54 PM   #2
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Bad racing fuel ?????
No matter who's fuel I use,when I pump from the barrel I don't stick pump to bottom of barrel in case there is any water and that is always possible.
They may pumped off bottom of barrel and you got mixture of water and gas
Mike Taylor 3601
Old 10-09-2014, 12:55 AM   #3
CFMCNC
A good investment for the trailer is a Specific gravity tester,Computech has a fair priced one.One way to tell if the fuel is going bad is by weight as bad fuel often will weigh heavier .Bill C.
CFMCNC is offline   Reply With Quote
