Old 10-02-2014, 10:14 AM   #1
Lyn Smith
Liked 980 Times in 197 Posts
Default Gm 6.0 litre v v t v8 tow vehicle engine
Anyone have a newer GM tow vehicle with the GM 6.0 litre v v t engine? How does it perform?
Old 10-02-2014, 11:23 AM   #2
dennis dunlap
Default Re: Gm 6.0 litre v v t v8 tow vehicle engine
Lyn we have two of them with the 6.0 in them both 3.73 gears, plenty of power, the allision trans is a big plus for towing ....
dennis dunlap is offline   Reply With Quote
Old 10-02-2014, 11:36 AM   #3
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I have a (6.0) 2008 (2500 HD) and it pulls by wagon like it was nothing.
Bob Bender 144 O/SA
Old 10-02-2014, 01:13 PM   #4
cad
cad's Avatar
Liked 91 Times in 51 Posts
Lyn,
I bought a brand new 2014 crew cab LTZ 4x4 6.0vvt in February, and it pulled like it had 200hp. RUN AWAY from the new 6.0 trucks. Before you buy, hook up your trailer and run it down the highway.
If you are pulling an enclosed trailer, it will not even be able to run in overdrive at 65mph on flat roads if you have a headwind without pushing it hard.
I tried premium fuel, e85, and had no luck.
With 4000 miles, I towed my 8000lb 24' enclosed from Omaha to Eddyville and got 7.04 mpg from Omaha to Des Moines while trying to run 70mph.
On the hills, the tach was pegged at 4400rpm trying to keep it at 65-70.
I traded down for a 2012 2500hd Duramax and havent looked back.
I got just under 11mpg running 75mph from Omaha to Denver for the ET Finals and the truck never downshifted.
In town/part highway empty, the 6.0 mpg was less than 11.5mpg. Duramax gets almost 18mpg on the highway empty.
Clark Doukas
Old 10-02-2014, 01:34 PM   #5
Ed Carpenter
Ed Carpenter's Avatar
Liked 520 Times in 132 Posts
I have a 2001 1500HD with 200,000 miles on it. Towed to Columbus and back in May almost 3000 miles round trip. I have a 24' trailer 3000lb car plus scooter tools spares etc. Still going strong!
Ed Carpenter
2005 Chevy Cobalt A/SM
Race Engine Development
Old 10-02-2014, 02:58 PM   #6
vetteboy
Liked 2 Times in 2 Posts
I had a 2000 with the 6.0 and pulled a 24’ enclosed trailer (9500 LBS) and it pulled ok. You will get 6-7 mpg. My dad had 2007 5.3 (3:73 gear) he pulled a 20’ enclosed trailer and that work ok. when he bought a 2012 5.3 it had 3:43 and the 6 speed trany it wouldn’t pull it. so he traded it in and bought one with the 6.2 (3:73 gear) and that has a lot of pulling power. If you plan on doing a lot of pulling get a Duramax. I have a 2011 duramax now and the difference is night and day. Once you pull with a diesel you will never go back. Brett
vetteboy is offline   Reply With Quote
Old 10-02-2014, 03:14 PM   #7
Tom Moock
Liked 10 Times in 6 Posts
I had a 2013 Chevy crew cab 6.0 2500 4 wheel 4.10, it made it to 5000 miles and I trade for new 1500, the 1500 5.3. With 3.46 gears pulled better than the 6.0 and got better mileage. Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 10-02-2014, 07:34 PM   #8
Jeremy1374
Jeremy1374's Avatar
Originally Posted by cad View Post
Lyn,
Clark Doukas
Just out of curiosity what do you figure your avg MPG are? Is this a 4WD & what cab/box configuration is this?
Jeremy Erny
Jeremy1374 is offline   Reply With Quote
Old 10-02-2014, 07:43 PM   #9
Jim Cimarolli
Liked 166 Times in 46 Posts
Cool Re: Gm 6.0 litre v v t v8 tow vehicle engine
I don't own one, but I have worked on my share of them. Sadly, I rarely ever hear anything good about a 6.0 when it comes to towing and mileage.
Jim Cimarolli is offline   Reply With Quote
Old 10-04-2014, 09:55 AM   #10
cad
cad's Avatar
It was a loaded 4wd LTZ Crew Cab. I think the average on the DIC was just over 10 when I traded at ~4600 miles. With a 34 gallon tank, towing 90 miles round trip to the local track and back, and 50/50 in town/hwy unloaded the rest of the week, it would only muster about 270 miles per tank (refill was about 28-30 gallons...somewhere in that range) on 89 octane gas.
I hooked up an inexpensive OBD2 dongle and monitored timing while towing once. On the flat with little wind, the VVT technology would alter the timing constantly. As low as 9 degrees and never more than 24 while towing.
Here is just an estimated mileage/cost calculator I used to convince my wife to let me dump a brand new truck for a Duramax. Note the cost per year in fuel...
