Old 09-19-2014, 06:16 AM   #1
Greg Barsamian
Liked 427 Times in 97 Posts
Default Re: Good ratchet tie downs
http://www.amazon.com/Allstar-Perfor.../dp/B003BZQTVU
Allstar-Performance "Direct Hook" ratchet straps are manufactured by M&R.
The "Direct hook" model makes "ratcheting" easier, due to fact that the "floor" or "rear" hook is bolted to the body of the ratchet (not to a strap extension)
When used with a "Flat Delta Ring-sleeved axle strap" the "Direct hook" model provides the "leverage" needed when trailer mounts are located close to or under vehicles.
"Direct hook" ratchet tie downs are a popular choice for use in "stacker trailers" with lifts.
