Old 08-30-2014, 06:50 PM   #1
John Nechiporchik
Liked 13 Times in 7 Posts
Default Hurst Quarter stick
Will a Hurst Quarter stick for a Turbo 350/400 reverse pattern work on a metric 200 trans?
John Nechiporchik is online now   Reply With Quote
Old 08-30-2014, 07:55 PM   #2
Brian Fink
Liked 28 Times in 9 Posts
Default Re: Hurst Quarter stick
If you have the automatic one / two shift it will work great ; it becomes a forward rather than reverse pattern however .
Brian Fink is offline   Reply With Quote
Old 08-30-2014, 10:01 PM   #3
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Turbo Action Cheetah shifter works great with a THM 200 ! That is what was in that car when it had a console.
Old 08-31-2014, 08:42 AM   #4
Kegracing
John,
I used the same Turbo Action shifter in my 87 Firebird with a Th200 and Th350. No changes needed, other than initial setup.
Know the shifters are a little different, but patterns were the same distance. I would try it and see.
Good Luck.
Ken
Stock 412
Kegracing is offline   Reply With Quote
Old 09-01-2014, 11:36 AM   #5
Jim Cimarolli
Liked 166 Times in 46 Posts
Wink Re: Hurst Quarter stick
I did it, just had to use a different cable bracket at the trans.
Jim Cimarolli is offline   Reply With Quote
Old 09-01-2014, 11:53 AM   #6
John Nechiporchik
Thanks.
