Old 08-22-2014, 11:24 AM   #1
azssamx
Default All new 1970 amx stk/ss roller
Now selling this incredible 70 AMC AMX STK/SS or could be made street legal again.
You can run the following classes maybe others.
Stock Class: 360 is factored to 280 HP and will run in F/S - G/S - H/S stick or auto
Stock Class: 390 is factored to 315 HP and will run in C/S - D/S - E/S stick or auto
Super Stock Class 360 is factored to 268 HP and will run in SS/I - SS-J - SS/K stick or auto
Super Stock Class 390 is factored to 315 HP and will run in SS/G - SS/H - SS/I stick or auto
Edelbrock heads are NHRA legal for all applications.
Over $30,000 invested in quality parts and fabrication, ready for your engine and trans.This is an original California 390 AMX have set up for 4spd or auto. The body is finished in beautiful Matador Red base/clear and features Ram Air hood. All exterior trim has been polished, perfect lenses and grill and rechromed bumpers. Chassie is set up for STK or SS with NHRA approved 8 point roll bar, multiple weight bars, Cal trac rear suspension,springs,Cal-Trac bars, SUB FRAMES tied and Strange aluminum adjustable rear shocks. All new front suspension,lite weight springs and aluminum QA-1 shocks. Brakes are disc all around with willwood super lite fronts and Mark Williams dual calipers on the rear. Rear axle is a trussed 8 3/4 Mopar with 35 Mark Williams Axles and lite weight spool. Wheels are Weld draglites. Fuel system is a complete BG pump with return system and aluminum cell. Interior has been restored to better than new featuring new door panels,carpet,headliner dash pad etc. Stock dash has factory speedo and Auto Meter lite gauges, Carbon fiber dash overlay and full painless wiring harness.Please call with any questions. No Trades cash sale only offered at 14,950.00 Contact Mark @602-738-5196
SALE PENDING
Last edited by azssamx; 08-28-2014 at 12:14 AM. Reason: updating STK/SS Class options
azssamx is offline   Reply With Quote
Old 08-23-2014, 01:19 PM   #2
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: All new 1970 amx stk/ss roller
You have a PM.
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-23-2014, 07:11 PM   #3
jeff klei
Question Re: All new 1970 amx stk/ss roller
Tried calling your number. Did not work. Please check your number. Thanks.
jeff klei is offline   Reply With Quote
Old 08-23-2014, 09:10 PM   #4
jeff klei
P.M. also sent. Thank you.
