Liked 171 Times in 36 Posts
2 things I see...
It looks like you need to adjust the rear toe-in a bit. When the rear squats, the rear tires toe-out, reducing the contact patch. Ideally, you want the tire straight up and down when the rear is under load. In the first video, the tires look like they are toe'd-out too far after the hit. It also looks like you are basketballing the rear tires a bit too. I'd keep the softer springs in it and adjust the hit with rear shocks and clutch settings. That will help get rid of the basketball effect. Hope this helps. |
Brett,
I used to run an IRS in my C/S '71 Corvette, and the set up that worked best for me was a heavy rear spring (600 lbs/in), and lots of base pressure in the clutch. This helped the front end to come up high, which planted the rear suspension, and stopped it from bouncing. 60 ft times were in the 1.50-1.52 range with low 11 et's. Of course the high base pressure eventually left me with a broken inner axle. I'm not claiming to be an expert because there are a lot of things that I never got the chance to try, but in my experience, the more power I was able to put to the rear tires, the better it responded. Good luck, and have fun. -Ben |
I think you can drop the base another turn. I have my 66 vert down to 280 lbs with 11.8 grams of weight on Tim Hyatts levers. What size slick is that? The 3300 lbs, is that with you in it. My 66 with an aluminum headed small block hard top only and no bumpers, full stock interior came in at 2805. Did you do anything to front end for bump steer? My front is almost on bump stops and the nose is almost fully extended all the way down the track.
Liked 16 Times in 11 Posts
"the nose is almost fully extended all the way down the track"
L-79, There in lays a problem, the reason your frontend is in the air is because air is pushing it up as you go down track. Get it to settle back down and you will pick up et and mph.
Bob Pagano A/SA |
#5 | |
![]() Last edited by L79racer; 08-18-2014 at 05:23 PM. |
Its been many years since I ran mine, front end was done by Jack Arnew and there was a big difference after the car was done. Can not say a spoiler would help or not, could not use the in Stock or SS unless the car came with them. Some company makes a shock that locks down when you hit the switch, been a long time so cant remember that either....getting old sucks. bp
Bob Pagano A/SA |
But, it beats the alternative.
That's how you have to think of it.
Bobby & Norene Zlatkin L/SA |
