#11 |
Liked 160 Times in 51 Posts
I check valve drop (P/V clearance) in approximately the same range as the other posters but also set up a handy spread sheet that takes those valve drop reading readings and also contains my theoretical valve lifts at those designated points. My spreadsheet calculates P/V clearances by doing the simple adding and subtracting and giving me a total P/V clearance. I also set up some conditional values in Excel that turn the cells red if I'm below a minimum P/V threshold. I've found building a P/V spreadsheet useful because I can move the cam degree cells left or right (simulating advancing or retarding the cam) and see what the new P/V clearance should be with the cam at those various places. Using a P/V spreadsheet also allows me to check a different cam in a bare block with a crank, get the lift @ degree numbers off of that new cam, punch the numbers in to my existing motor valve drop measurement sheet and recalculate new clearances.
As always, you DO need to physically check P/V clearance that math=actual clearance but so far it has worked great for me.
Brian Thompson NHRA Stock / Super Stock Class P/SA 6665 SS/MA 6665 |
#12 | |
Liked 285 Times in 87 Posts
#13 |
I only do "valve drop" measurements to verify all cylinders have the same valve seat-to-valve pocket travel. I would never just do math to check my valve-to-piston clearance. I actually measure it in 2 degree increments 20 degrees from TDC. I have found the closest point being ten degrees from TDC to almost never does apply to my stuff. I measure it with the springs I'm going to run. I have an old Mr. Gasket on-car valve spring checker that I have modified to fit my Jessel rockers, to pull them down against the pistons. I use a long 1/2" drive break over instead of the torque wrench it was meant to use for checking valve springs. Checking with weak checking springs always show less room than it will have running.
I measure it with the cam two degrees further advanced than I expect to run it, and backed up two degrees further than I would expect to run it, on a new engine. After I settle in on where I'm going to be running the cam, the next time it's apart, if I have room, I close it up to the minimum. My pistons have a clean ring like the face of my Manley valves, and a round dark spot for the dimple in the center. I quit using modeling clay about 1970, when Carrol Caudle told me "Ed, give that crap to a kid to play with, that is what it is meant for." LOL If somebody tells me they bought an engine, and how much clearance should it have, I'm going to tell them way safe to keep them out of trouble.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 08-06-2014 at 06:51 PM. Reason: Fixed it. Sorry. |
#14 |
Thanks for all the replies
#15 |
#16 |
LOL! Nope, never tried that one. You might be too young to remember all the magazines showing how to use modeling clay, then measure it with a machinist scale or veneer calipers. That is all I had to go by until I met Carroll. He was the first sharp engine builder I got to know. Taught me a lot.
Ed Wright 4156 SS/JA |
#17 |
Liked 166 Times in 46 Posts
Ed, does he still have his old '55 Chevy?
#18 |
Yes he does. He sold his Don Hardy Vega, still has his last (he had three) '55.
#19 |
Liked 140 Times in 51 Posts
#20 | |
I also used modeling clay many moons ago, also used Plastigauge too! |
