Old 07-29-2014, 01:01 PM   #7
Lee Sherburn
Default Re: 427/428 ford fe's
I guess I am confused with hooking up my powermaster as the tilton starter I removed only has the battery cable hooked to it. So what do I hook the terminal marked switch on the selinoid to? Guess a picture or drawing would help.
#4 on the instruction sheet that came with it plainly says( ATTACH BATTERY CABLE AND SWITCH WIRE. The switch wire should be capable of handling 25A. Switch wire to where?
Thanks Lee
Lee Sherburn is offline   Reply With Quote
