Old 07-26-2014, 02:42 PM   #1
carsjcarter
Default 1967 camaro stocker
i am starting the build of a 67 camaro stocker 396 325 hp was curious of a few things like rear wheel backspace can i run a rear spoiler with a cowl hood can i move the rear shocks on the back of the car? It has been slightly mini tubbed do i have to put that back to original
carsjcarter is offline   Reply With Quote
Old 07-26-2014, 04:29 PM   #2
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: 1967 camaro stocker
You need to get a rule book and go from there.
Old 07-26-2014, 04:43 PM   #3
Alan Nyhus
Liked 799 Times in 236 Posts
-Cowl hood: That's only for some '69's. Your combo used the raised SS hood.
-Rear shocks: Must be in original location.
-Mini tubs: Must be original inner fender wells.
As far as spoilers...not all '67-'69's can use the same combinations of f/r spoilers. I'm sure someone will clear up what can be run on your '67, though. -Al
"That'll never work....."
Old 07-26-2014, 09:13 PM   #4
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
I run a 396/325 motor. Look for the "290" heads, they came on 427/390 motors. Highest intake volume oval port heads made-
Good Luck!
Will Lamprecht 65 Impala I/SA 396/325 in progress.
Old 07-26-2014, 11:26 PM   #5
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
15x10 w/5.00 backspace here. Pretty close, about the most you can get under these cars.
Rich Taylor
I/SA - 321
Old 07-27-2014, 01:47 AM   #6
Dave Noll
Dave Noll's Avatar
Liked 240 Times in 112 Posts
WOW !!! Look @ all the shiny. Nice.
Dave Noll, EF/S ,?/SA 6526
Dave Noll is online now   Reply With Quote
Old 07-27-2014, 12:17 PM   #7
Larry Fulton
Larry Fulton's Avatar
Look'n Good!!
Larry Fulton
Larry Fulton is offline   Reply With Quote
