Old 10-11-2007, 07:35 PM   #1
CycloneFE
CycloneFE's Avatar
Liked 2 Times in 2 Posts
Thumbs up Re: ford truck help needed
I second that!! Did the same(hours included) on my 5.4. I used a thin wall socket to loosen and tighten but had to use a regular spark plug socket to remove and reinstall. I needed the rubber inside to hold the plug when taking it out and reinstalling them, but had to switch back to the thin wall socket to tighten.
From a Ford fan, that wasn't their best idea.
When I finished mine I thought I would do the wife's Jimmy with the V-6, should be a piece of cake. Wrong. Undo motor mount, jack up engine, change plug behind steering column. Wasn't GM's best idea either.
