#1 | |
Liked 427 Times in 97 Posts
I've already replaced the tubes w/ DOM tubes, and added MW caps? Is it safe to run the smaller bearings? The Moser housings for the A & G bodies do not incorporate the "bumper tab" for Weibe Suspensions? Greg |
Liked 783 Times in 195 Posts
Yes, you can. You will have to use MW housing ends for large axle bearings. Call MW and tell them what you are doing.
#3 | |
Liked 345 Times in 149 Posts
Agreed. I have Mark Williams 35 spline axles (no drilled) in a 12 bolt which has been in service since the mid 90's. All the internal parts are holding up extremely well and have not replaced anything other than gear sets for tweaking of ratios with combination changes. The MW captured bearing housing ends are really nice as well. 11/16" drive studs, billet caps and a girdle cover should be on the parts order list as well. Last edited by Todd Geisler; 10-11-2007 at 03:09 PM. |
I thought you could only fit 35-spline axles in a housing with a 3.250" bore, or is that only if you want to run an aluminum spool? Or is that just completely incorrect?
How much better is a billet driver side cap than a support cover with factory caps? What about two billet caps compared to one?
~Pete 1970 Nova |
#5 | ||
Just adds more rigidity to the housing and will not break. |
Can a "stock" GM 12-bolt be machined to accept the 3.250 bearing to use an Aluminum Spool?
From a machining standpoint, I have to believe it's possible - it was done once when the housing was built. But from a strength standpoint, I suspect it would weaken the housing too much: your billet caps would probably take it, but there isn't much meat to spare ahead of them in the case, and it also wouldn't leave much metal between the bore and the bolts.
![]() How do you remove the stock axle tubes, and where do you find DOM axle tubing?
~Pete 1970 Nova |
