Old 06-10-2014, 10:34 PM   #1
randy wilson
Liked 22 Times in 22 Posts
Default Re: Hardblock Question
We've had this discussion before at least 2 times. My thoughts, for what it's worth is I would never fill a block. And I've filled 5 or 6 before. I never gave it much thought until a very experienced engine builder showed me after my first teardown how much chatter the honing stones had. Well, I told him the next time it would settle down and hone smoothly. Wrong! It was worse. So we did an identical 283 block with just deck plugs, and no chatter after 4 rebuilds. Just my experience. I would not fill any block. Get an aftermarket block, or get a good stock block and use deck plugs, and no filler. Bowtie or after market preferred.
don,t have one
Old 06-10-2014, 10:44 PM   #2
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
I fill the blocks and let them sit at least a month with both heads and main caps torqued before boring, never an issue with honing, I use Halco machine grout.
Old 06-11-2014, 07:10 AM   #3
bob3240
Liked 16 Times in 5 Posts
I had the same experience about cylinders going out of round, even after letting it dry for 30 days. .005 -.010 at the bottom of the bores. Car started smoking it was so bad!
bob3240 is offline   Reply With Quote
Old 06-11-2014, 05:27 PM   #4
CFMCNC
X2.Needs a month to cure correctly under stress of heads and mains torqued,also we put a 1/4 plastic tube in the water jacket to the drain plug ,after curing we pull the tube out and have draining access.Mostly use aftermarket blocks now.Bill C.
CFMCNC is offline   Reply With Quote
Old 06-11-2014, 07:19 PM   #5
BillK
Liked 30 Times in 17 Posts
I have never seen much of an issue with Hard Block. I did have a customer use one of the other brands and he had a heck of a time. Took a couple of freshen ups for that stuff to settle down
I am getting ready to fill a SB Mopar block, maybe I will do some measuring before and after and report back ?
Bill Koustenis
BillK is offline   Reply With Quote
Old 06-11-2014, 09:12 PM   #6
SSDiv6
Although Hard Blok claims the expansion rate of their product is the same as gray cast iron, when I spoke to them, they could not tell me how they based their claim.
On the other hand, Embecco 885 is a fully tested product for use by the government, with lots of supporting data and it contains cast iron in its formulation. Never had any issues with the product and the blocks have never changes in the block dimensions.
Old 06-12-2014, 07:38 PM   #7
randy wilson
I'm sure there are people who do fine filling their blocks. Just telling of my personal experience. It NEVER settled down for me in any block used. To each his own. We may have actually applied it wrong.
don,t have one
Old 06-12-2014, 10:48 PM   #8
Steve Williams
I wouldn't fill with hardblock or any aggregrate based filler. I have been using bowling ball epoxy with excellent results. Mix it to the ratio listed on the bottle and it is easier to fill and cleaner overall. Water jackets need to be clean though, no debris or coolant or oil.
Steve Williams is offline   Reply With Quote
