Old 05-17-2014, 06:22 PM   #1
Kevin Panzino
Kevin Panzino's Avatar
Liked 748 Times in 137 Posts
Default Manley 10° +.050" locks poor qa/qc ???
Has anyone else noticed the Manley 13198 (11/32" stem, 10°, +.050" installed height, machined steel) valve locks come out anywhere from .065" to .073" additional installed height ?? A far cry from the specified +.050" additional????
Not only is the fact that they are that far off somewhat concerning, but the variance from .065" to .073" between locks in one package scares me... If the two locks installed a valve are not exactly the same dimensions, one of the locks will have almost all of the spring load on its groove rather than shared between the two
Kevin Panzino is online now   Reply With Quote
Old 05-17-2014, 06:29 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Manley 10° +.050" locks poor qa/qc ???
Sorry man! I had a brain f*rt. Mine are Comp. Always checked correctly.
I should just keep quiet.
Ed Wright 4156 SS/JA
Old 05-18-2014, 02:54 AM   #3
MAURICE BLENDHEIM
Liked 284 Times in 87 Posts
Kevin…We have also experienced the same problems. Manley retainers have been an issue for us too. Alternative choices were made to get around it. Hopefully they are not trading Quality for "offshore" profit. MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-19-2014, 10:56 AM   #4
ss wannabee
Liked 7 Times in 7 Posts
Who makes a decent retainer/lock today? I've got Crane and Lunati pieces...but
nothing in the added height should I need to go there....The ones I have hopefully were
made in the good 'ol USA...as they have been here for quite some time...
Anybody get 'em from Trick Titanium?
ss wannabee is offline   Reply With Quote
Old 05-19-2014, 12:30 PM   #5
Ed Wright
Ed Wright's Avatar
I've had good luck with Comp.
Old 05-19-2014, 12:34 PM   #6
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Same here on Comp
Mike Pearson 2485 SS
Old 06-01-2014, 02:48 AM   #7
trmnatr
Crane Posi Stop or Titanium. I try to use the posi stop when I can. They are specific sizes. If you can not use a standard Posi Stop because the standard lock won't work with your valve, use Crane Posi Stop's for 3/8" valves, and use Multi Fit Crane locks. All their Multi Fit is based on 3/8"
trmnatr is offline   Reply With Quote
Old 06-01-2014, 09:18 PM   #8
BillK
Liked 30 Times in 17 Posts
Kevin,
One thing I have found on the Manley locks and retainers, they measure different when used with another manufacturers parts. For instance if you take a Comp retainer and measure the installed hgt with a Comp lock, and then try it again with a Manley lock, it will measure different. I found this out a long time ago. I pretty much stick with one manufacturers parts. If I am using Comp retainers, I use their locks. Comp seems to be the most consistent over time. I have some single Comp retainers I bought 15 years ago for checking stuff and they still are identical to what you buy today. I would bet Crane is the same way. Cant say that for most other brands.
Some of the less expensive house brand stuff is the worse, it will vary from part to part in the same package
Bill Koustenis
BillK is offline   Reply With Quote
