Liked 325 Times in 50 Posts
The Mopar's use a 4 hole 1 3/4 in on the DP's which is the same size as 750 CFM 4150 series carb, but it is rated @ 1000 cfm. The 426 Hemi uses a 2" which is the same as a 4500 series base and is rated @ 1600 cfm. Course we are only flowing air. The Copo 427 single blade has a slightly larger area than the 2" 4 bore that we use.
Jeff Teuton 4022 STK |
Liked 122 Times in 11 Posts
The 429 is our answer to the 426 Hemi, and the 427 Chevy. The cam lift is line on line with the Hemi combo.
The throttle body is our off-the-shelf unit. Big but front entry as opposed to the scoop of the Hemi. I consider it a wash. Likewise the head is 12 year old NASCAR tech but it's off-the-shelf as well. However the 429 is at .650" lift while the NASCAR engines are over 1". Huge difference! It becomes an apples and oranges argument trying to compare the engines. These engines are designed specifically for Factory Showdown. It should be very fun and exciting, and not affect any older combos as the natural class is BB. The Dodge guys are dominating FS/B right now and we want to mix it up a little. The point is to promote Stock racing and help Factory Showdown grow, having all 3 makes in is a big part of that. Hopefully Chevy ups their ante with a .650" lift SOLID lifter cam and maybe a CNC port on their intake like the Dodge has and we should be VERY level in performance. I think we've got the best teams running Ford's (although I do like the Barton and Teuton teams) and I'm excited for Indy. I hope the Chevy guys get a combo that gives them the specs to be right inline with the Ford and Mopar so we can stop the paperwork exercise, get to work and settle this on the track.
Jesse Kershaw |
#3 | |
Liked 1,112 Times in 304 Posts
Liked 46 Times in 12 Posts
You tell those guys like it is Jesse. It is like the phrase you always tell me that you are tired of taking a knife to a gunfight.
Liked 9 Times in 9 Posts
Am I the only guy who wishes these cars would be "Pro Stock" instead of the current class?
Joe Toller Lewistown, MT |
Liked 184 Times in 113 Posts
Liked 444 Times in 145 Posts
No you aren't. There are many more folks who despise these cars in Stock and Super Stock than there are who want them in. The OEM guys chime in only when there is massaging that needs to be done. History will provide a very dark view of their actions. But what do they care?
Bruce Noland 1788 STK |
#8 | |
Liked 293 Times in 65 Posts
"instead of the current class" - I can't speak for Joe but it appears that he thinks these cars would be better suited in Pro Stock than running them in Stock. And I agree with that.
